We purchased a home with a 20k gallon pool and the Hayward Star Clear C3000 filter that I assume to be original to the pool in 1995 or 1996. I ended up doing a lot of maintenance to the filter last year including sourcing a discontinued outlet fitting used, the filter base, new seals and new filters. I've probably sunk about $300 into baselining what I had because it was there.
I'm about to convert the plumbing to salt water chlorination and I have a Circupool Core55 waiting to get plumbed in (need to move the pump and filter back to make the 11" of pipe space that I need.
I figure while I'm reconfiguring plumbing, maybe it's worth replacing the antiquated filter that I've limped to semi-stable condition but who knows how long it will last?
I was also already considering adding a Pre-Filter so this combo appeals to me.
Is this enough filtration? Seems like 150sqft less than my larger filter but with the Pre-Filter and easier maintenance, it seems worth the minimal cost over just adding a Pre-Filter to what I have.
Thoughts? The one piece I couldn't replace easily on my Hayward filter or cost effectively was one of the clamp pieces that would cost me an entire clamp to source at about $150-$200 which I haven't wanted to do.
TWO-STAGE FILTER SYSTEM (CJ-150 Filter & TJ-16 Pre-Filter)
www.discountsaltpool.com
