Replace colorlogic transformer
joseeliseu
2
Senhas123!.!
Hello everybody. I just bought a house, came with a pool with whole hayward system. Spa light never worked. It has power up to the junction box. I assume light is out. I still have to figure that model / niche out.
Now my big 10" colorlogic for the pool will turn on and go off 1s later. You can hear relay clicking. My guess is transformer, although I haven't studied it too much. My question is: can I replace it with any transformer (as long as it's got enough w to run it) or will I lose color change feature if it's not the original one used by hayward...
Also, how to figure out which model light I have before I pull it out?
Josee,
Pool light transformers are special...
The are built in such a way that the Primary side (120 Volts AC) can never short over to the Secondary side (12 Volts AC.) They are 'rated' for pool use.
You can't just use a standard off the shelf transformer. Period!!!
Reactions: proavia
Josee,
I get that part, what I mean is any pool light transformer will work... doesn't need to be hayward's brand. Right?
Right? No.
Hayward transformers have a snubber that keep the ColorLogic Lights from falling out of sequence with each other.
If you use a non-Hayward transformer you should install the snubber as this document shows.
Hayward Colorlogic Snubber
  • Snubbers & Lighting-1.pdf
Reactions: proavia
If you only have up to 4 lights you can use any pool/spa light transformer without a snubber. If you have more you should use a snubber. Make sure to get a transformer that can handle all the lights. I don’t know about the 10” color logic but the Hayward 320 LEDs are 25 watts a piece.
