- Jun 2, 2014
- 24
- Vinyl
- Pentair Intellichlor IC-40
A week or two ago I added a bag of salt and didn’t notice it was a bad (really dirty) bag of salt till most was already in the pool. It made the water cloudy, but a lot settled out in the bottom of the pool over the few days it wasn’t used. I manual vacuumed, but the particles are so fine they seem to be going right through my cartridge filter and I keep having the same issue over again. Unfortunately, I had cleaned the cartridge filter shortly before this issue, so that could be part of the problem (no dirt in it already to increase performance...had to get all the worm guts out from opening in May).
Any ideas of how I can get my water clear again without waiting for the filtration to get better by itself over time as the filter gets dirtier? Any filter aids that can be used with cartridge filter? I have a large filter that really only needs cleaned once a year, so it takes awhile to even build up any head loss. I can’t vacuum to waste unless I add a bypass valve to my piping and not sure how much water I would suck out and need to replace with more water and salt.
Thanks.
Thanks.
