Generally speaking you only need to run your pump long enough to cycle the water at least once per day, so we can do some quick math to see what that works out to. Cut the time down to that then make sure your chlorinator is keeping up.
So SPX3200A is actually the part number referring to the pump housing for the Tristar series, which is universal for all motor/impeller size combinations of that Series. The motor you specified is a 2.5HP with a 1.04 SF (2.6THP), which corresponds to the SP3220X25 model (see attached spec sheet). Unless your hydraulic head is >75ft (very high), or you have 2.5" piping, that pump is going to be pushing the max amount of flow that a 2" pipe can handle (~83GPM). At 83GPM you only need to run the pump 5 hours to turn the water once (assuming 25k gal pool).
If you want to get serious about energy savings, look into a VGreen VS replacement motor. It will mate up perfectly with the Tristar square flange. You would need the ECM27SQU (2.7THP) which may be hard to find since it's discontinued. The EVO is the new Century VGreen model, but it looks like they max out at 2.25THP, so you would have to downsize the impeller to the SPX3215C. Still should be more than enough to turn over your pool water.
Explore our Pool Pump Motors with 2.70 HP, 1 Phase, 60 Hz, 230V. Operating at 3600 RPM, this 48Y motor comes Totally Enclosed Fan Cooled, delivering reliable performance for your applications.
www.regalrexnord.com
