The reasoning behind the chlorine soak is strictly for disinfecting. Hosing off gets rid of debris. Cartridge cleaners are meant for degreasing. I don't know how effective they are at disinfecting. I do know that chlorine is about as good as it gets when it comes to disinfecting.
I agree that there is not much of a need for CYA with an indoor pool.
If you aren't losing water, sealing the autofill from the pool, shutting off the supply, and sucking out the water might not be a bad idea.
I think it's likely that that was the source. The lack of use let the water stagnate.
Scott
Scott
