- Nov 15, 2022
- 54
- Plaster
- Jandy Aquapure 1400
I just installed a Jandy Aquapure SWG, got all my levels right and just turned it on today. The salt sensor on the Aquapure is consistently 300ppm higher than the Taylor K-1766. When I tried to follow the instructions to calibrate it, I ran into a snag. Everything I read says to hold the Salinity button for 15 seconds (3 beeps) and then press the temp button within 5 seconds to enter salinity sensor calibration mode. It never beeps, and it doesn't ever seem to go into calibration mode.
I also tried the steps to configure the alarm volume - hold temp button for 15 seconds (3 beeps) then press salinity - same thing, no beeps, never enters config mode.
I saw some other instructions to check firmware version - that seemed to work - the firmware is 01220A15
When retrieving the firmware, there were 2 additional numbers after the firmware version: 05 and 180. If I press the up/down arrows, the 05 looks like it allows values from 05 through 69 - what's that?
