- May 3, 2007
- 16,974
- Plaster
- Hayward Aqua Rite (T-15)
For Goldline units, 3 parameters are used for determining salt level, voltage, current and cell water temperature. So even if the volts and amps is the same, if water temp is different it will change the salt level.
But 8.25 amps is over limit so it should have alarmed. Are you sure it wasn't 6 amps? That is nominal.
