Thank you very much for the advice and empathy. Truly appreciated
"IF" you were to confirm iron, stick to ascorbic acid. Oxalic acid isn't a good bulk treatment since it precipitates with the calcium in the pool. Spot treatments are acceptable.1) is AA more gentle than oxalic acid?
Fill more accurately. Pool water iron tends to get tricky with chlorine interferance.2) can I test for iron in my pool water and in my fill water?
Iron - polyfill "IF" the particles are large enough to be filtered. Copper you can't filter. I believe we addressed this was discussed on page 1.3) how do I get rid of metals and metal ions in my water--is it to use a sequestrant and polyfil in a skimmer sock in the skimmer? This is the polyfil you buy for pillows and toys?
They can be beneficial to contain metals in solution. Some stains already embedded may not lft and need more aggressive treatment.4) or do I just need to use a sequestrant regularly?
I doubt it in your situation. We highly suspect your water was compromised with copper from the old/bad heater. As such, you may need to perform the copper treatment and water exchange @JamesW recommended in post #9.5) will filters that attach to my hose stop this problem when I add new after? If so are there any specific recommendations?
I can't see the color change as well as you Mike. But if that's true, then yes, the improvement from a tablet would be indicative of an organic stain, either on the surface or partially embedded by scale.Does this mean anything Pat?
What exact tests did you do?I've tried all the tests, multiple times and multiple ways and it's not clear what the stains are
There are very apparent on my cell phone, not so much on PC. There are at least 10 lightened circles, some with the telltale comet trails heading downhill.I can't see the color change as well as you Mike. But if that's true, then yes, the improvement from a tablet would be indicative of an organic stain, either on the surface or partially embedded by scale.
And that would be a sign of tannin from the dropping of seeds/acorns or something like that falling into the pool from a nearby tree. I'm on a PC right now so I'm not seeing it, but maybe @NewPoolGirlTX can confirm.some with the telltale comet trails heading downhill.
Oh BELIEVE ME. I am concussed at this point.In the meantime, there's always this approach.
In the photo below, there are obvious spots that were lightened by tablets. There are more than the ones I circled, but these are the most obvious. Depending on the device you're on, they may or may not be apparent. I assume they were trichlor, so unless they were there previously, either the chlorine or acid lightened the stains. Does this mean anything Pat?
what tablets? I don't use tablets. the only time I've used tablets were trying to test the stains.The comet trails are from the tablets. Some of the lightened stains are comet-shaped.
I did the Jack's stain ID kit 3 times, I tried Vitamin c tablets several times, and I tried pH Down several times, as well as granular dichlor.What exact tests did you do?
Thank you so for the advice.Gotcha, well, at this point with such a relatively new plaster job, my bet is on copper like James noted. I just don't see iron as an issue unless you filled from a well or had old plumbing which you shouldn't. Plus, iron reacts very well to the Vitamin C test. Organic stains would also react quickly to tabs or cal-hypo that was applied, so I think that's out. This brings us back to the worse one (IMO) which is copper due to the bad advice (and heater) you had right after the initial fill. Unfortunately copper is one of the toughest stains to remove. Even spot testing can be tricky. I mentioned trying pH Down as a test, but if get your hands on some sulfamic acid and try to apply it to a small spot as a test, that might work better.
The other wildcard in your case is the plaster job itself. You had doubts about the quality of work, so there's a chance that the staining might be related to the plaster mixture itself or how it was applied. Perhaps even the support materials underneath bleeding through. If that's the case there's nothing you can do at this point.
If it were me, I would wait until Jan/Feb and do the sulfamic acid pool treatment. You can allow the FC to drop in the cold water and then exchange the water after the treatment is complete to remove the sulfamic acid and hopefully copper. If it lifts the stains, the you know it was all from that heater.
That's an oxymoron.what tablets? I don't use tablets. the only time I've used tablets were trying to test the stains.
No tablets have been used. I only had one tablet at all and used it to test stains. Nothing I have tried has lifted the stains noticeably and immediately, they way all the tests say they shouldAnd that would be a sign of tannin from the dropping of seeds/acorns or something like that falling into the pool from a nearby tree. I'm on a PC right now so I'm not seeing it, but maybe @NewPoolGirlTX can confirm.
