Ready to SLAM - selecting the correct sanitizer on the pool calculator
SCpoolboy
Active member
Jul 10, 2023
29
South Carolina
Pentair Intellichlor IC-60
Bought Walmart liquid chlorine to use. When selecting sanitizer type in the pool calculator which do I select? Tricolor, dichlor, Cal hypo 48%, 53% etc. I don’t see anything obvious on the bottle. Does show 10% chlorine on the bottle.
FC 6, CYA 67.
Hold up. I'm guessing you don't have your k-2006 yet?
Don't start the SLAM Process until you have that and have reliable numbers to base your additions on. Until then 5 ppm of chlorine per day will keep you in a holding pattern, not getting worse but also not doing anything that could come back to bite you because you trusted test results that weren't accurate.
