Hello, pool and tech-savvy friends. I need advice on diagnosing a spark issue I am having with my pool heater. I have a Raypak P-R406A-EP-C pool heater. The unit is about 8 yrs. old. My unit is the Atmospheric Heater with the Honeywell Millivolt Gas Valve (Model VR8304K4822) and the RobertShaw Millivolt Pilot. When I turn on the unit I am getting a "No Pilot Sensed, Ignition Lockout" error. I've vacuumed and cleaned the inside of the unit thinking that it was dust and spider webs that were causing the issue. I've checked all the gas valves to make sure it is on. I took a look at the pilot as the unit was being turned on and it doesn't appear that I am getting any spark across the igniter/sensor gap. I've then proceeded to verify the PC board for power. I've checked for 24VAC across PV-MV/PV terminal on PC board and I am getting 26VAC when firing up the unit (these two wires I believe send a signal to open the gas valve), so I presume that's ok. I've checked the T1 terminal (ignitor) in PC board and it appears that I am getting 120V. I am not smelling any gas or getting any spark across the igniter/sensor gap. Any ideas what the issue could be?
