When I turned the pump off (not realizing the heater was running), the heater started to shake and rumble. I quickly turned it off.
I followed the pressure switch adjustment procedure, but it did not work. I replaced the switch - That also did not work.
The control panel used to indicated "Water SW Open." The error does not show up and the heater continues to run, resulting in a loud banging and rumbling.
What in the world should I look at? All posts seem to be about the OPPOSITE problem!
Thanks in advance!!
Thanks in advance!!
