I just replaced the faulty control board of my AquaLogic PS-8 with the latest GLX-PCB-MAIN. All works well now, except the Raypak heater. The display panel on the heater is now blank, whether I toggle the rocker switch off or on. It should show RemOff or RemOn and the temperature.
The heater rocker switch is always "on", but the PS-8 is used to actually turn it on and off, and set the temperature. I have double-checked that it is connected and seated on the new control board. The PS-8 settings are all the same as they were prior to the board replacement.
I'm wondering if I need to disconnect the heater from the AquaLogic, reset some things, then reconnect. Can anyone explain what could be wrong?
