Hi everyone,
Another summer, another season of headaches with this heater. But I'm not ready to plunk down 4 G on a new one. My previous soldering job seems to have held up, but a new loose connection at the board from the temp sensor was giving me problems. Got it going again but it was short lived. And extremely frustrating. So I bought a replacement board (the newer type). While at it I put a new temp probe in for good measure, although the old one looked OK.
Soi hooked it all up, and it started right up. However, there is what appears to be a short somewhere, as the heater will randomly turn off (as in, lose power). A gentle bang on the outside is usually enough to get it going again.
The diagnostic mode shows voltage of 24.4, which should be OK from my understanding.
Any ideas where to look, or should I just replace all the wiring at this point? I'm even OK with hiring a pro, provided he can actually get to the root of the problem. The heater itself is older and has quite a bit of rust inside, but when it works seems to function well.
Thanks
Thanks
