Raypak 2100 heater
Please, DO NOT use that heater like that and replace that pressure switch NOW. It doesn't have to be in a RayPak box, any generic will work as RayPak just buys them from TecMark. Between $22-$24 online.
Of all the things someone can do to force a heater to fire, that is the most dangerous. That heater now "thinks" that there is enough water flow for it to safely fire, even with the pump off. You really don't want to see what a runaway heater can do. I've seen it twice and it isn't good. The temperature in the combustion chamber can reach 2000 degrees.
Yikes! I ordered that. And yesterday I had shut the gas off and the side panel power switch is off and its not currently wored to the aqualink. This was a rental that I've recently moved back in to. Sounds like I'm fortunate nothing bad happened.
