Hi everyone,
Have a worrysome symptom going on with the heater( Raypack 206A natural gas). When the heater is activated, the pr-blower comes on, the gas valve opens and the unit ignites normal. Later when the unit goes into another heat cycle, I hear a bif wooosh (small expolsion) and a short burst of flame from the bottoms. It seems like there is too much gas in the area when the heat element fires. Looking for some help.
I have recently replaced the burner tray, blew all the burners out with air and have checked to make sure all gas connections are not leaking. All rust and debris has been removed, I even removed the back panel after multiple explosions , to make sure it was well ventilated.
I believe the heater was installed in 2016.
See attached.
See attached.
