Hello, I've been slamming since last Friday (7/7) when I noticed some green algae spots in corners of the pool. I had previously been slacking a bit due to several rainy days and let my FC get below minimum unfortunately.
Today:
FC 12
CC 0
PH 7.2
TA 80
CH 180
CYA 40
Pump running 24/7 at 1725RPM. I have been brushing, haven't noticed any algae spots in a few days and made sure to brush under stairs, ladder etc. Robot runs daily and is emptied daily. Have been checking FC as often as possible (with an infant at home) and topping up to SLAM level as needed. Pool water is clear but I do get a lot of tree debris daily. Emptying skimmer basket multiple times a day and have backwashed once during the SLAM and added DE to my sand filter.
The last few days I have been noticing rapid FC loss as soon as sun hits the pool in the morning. Yesterday I went from 15 FC at 11am (when the sun came out from behind clouds) to 3 FC at 1:45pm. Today I went from 20.5 FC (overshot a bit last night) at 7:15am to 12 FC at 10:45am with sun out all morning.
I've done the CYA test over and over again on multiple days and I am as confident as I can be that it's 40. I am not passing OCLT so there is definitely something still consuming FC but the rapid loss due to sun is puzzling me.
As you all know, liquid chlorine prices are nuts this year so having to continually buy more is quite stressful. Any help is appreciated. Thanks!!
Today:
FC 12
CC 0
PH 7.2
TA 80
CH 180
CYA 40
