I've noticed a lot of folks have reported problems with Quikrete sand being too fine and getting into the pool. I've used Quikrete sand for the last four or so years. I recall when I initially filled the tank with sand there was a small but noticeable amount of sand that came out into the pool. I vacuumed that up and the filter has worked fine for several years. Last year I purchased another bag of Quikrete sand with the intention of replacing the sand in the filter as it was three or so years old. When I opened the filter I noticed the sand was in great shape after rinsing it out and it was not clumped up. I opted not to replace the sand but to "top it off" as the level was about 3" from full. When I turned the filter on there was again a very small amount that came out into the pool. I vacuumed that up and kept on trucking. The sand filter continued to work just fine over the course of last season. I plan to open up the filter, possibly today, and check the level and condition of the sand to see if I should replace it or just clean and top it off again. I'll try to remember to report what I find. My hunch from reading about others experiences with Quikrete sand is that, like others have said, the quality/size is not consistent and some amount, maybe 10%, is too fine and will wash out into the pool when the filter is operated. Once that occurs the remainder of the sand should be just fine. One can "top it off" if so desired but the amount that washes out is probably not significant enough to be much of a concern.
Note: When I initially filled the sand tank with one bag of Quikrete sand the level did not come up to "full" but was maybe 2" from full. So no, I did not lose 3" of sand during the course of using the filter for three years. It was not full to begin with and I'm sure there was some settling of the sand. How much did I lose? I would guess well under an inch. I know that's not a "volume" measurement. It's just a measurement from the "full" mark.
I am not an expert on this matter but am just posting my experience.
