- May 14, 2023
- 28
- Fiberglass
- Jandy Aquapure 1400
I just did the CH test using water right from the spigot that was used to fill the pool and it‘s only 175 ppm!Then you must have added alot of calcium or been using a lot of cal hypo. There is no way your CH is that high from fill water.
Unfortunately I don’t have a log of what’s been added to the pool other than what I’ve done starting this weekend. We’ve been paying a pool guy to manage the chemicals up to this point.
So now that I corrected the pH and TA, the CH is high and there is zero CYA. What do I do next?
