Here in Texas we haven't had substantial rains in many weeks/months. I may attempt a drain and refill in the future when the temperatures subside a bit and we are no longer in a Stage 3 drought. I'd prefer to do a full 60-70% drain prior to refilling in order to most efficiently/economically reduce CYA. Regarding the pool popping due to high water table, my pool is an in-ground above-ground hybrid of sorts (see photo below). The pool is sitting up on a rocky cliff that drops a couple hundred feet to a dry riverbed.
Is it safe to assume that there is not a water-table concern (in regards to draining the pool) at this site?
