I have a new Pentair Intelliflo pump which was installed by a qualified pool technician and licensed electrician including a installing a surge protector. Everything works great and I got a $250 rebate from Entergy,(electric utility) paid about $800 online for the pump. So far calculations show this will be all paid for including $200 installation after one year in savings from my Entergy utility bill.GREAT!
I did a lot of study for several months before pulling the trigger on this move but so far so good.
My question to members is when I set up the pump we used the basics of a single speed option I had questions about what the GPM Gallons per minute was for various speeds (the newest Intelliflo unit gives you that reading but you have to buy that model through the dealer and they want about $1800 for it so I opted for the earlier version) In any case I called Pentair customer service, a long wait online and reached a young man who really knew the unit and he helped me set up a very sophisticated program where I run for the first two hours at 2350 RPM and then 8 more hours at 1600 RPM which was a custom speed. It was for me a complicated procedure which he figured the first two hours would give the filter a couple of turnovers then lower the speed to 1600 to maintain the chlorination from the AquaRite unit. I asked him if there was material I could study to learn more of what can be done with so many options and he said not really- so my question is does anyone have sources for more info on using these units? Someone should write an in depth manual on the options you can set up with this unit. All comments are welcome
