aa62579
0
Re: Question on what chemicals to add to my 14' 48" intex po
Jeff - figured out something pretty cool about the size of your pool. Essentially, 1 cup of bleach = 1 ppm of FC. Therefore, if you do the test and you need to add 1 ppm of chlorine, you add 1 cup of bleach. If you are 1.5 low, add 1.5 cups of bleach. If you are 2 low, add 2 cups of bleach.
If you don't have any pH problems, for daily maintenance you won't have to keep referring to the pool calculator once you have all your target numbers down.
