- Nov 27, 2018
- 263
- Plaster
- Pentair Intellichlor IC-40
FC 5.5
CC 0
pH 7.8
CYA 40
TA 60
CH 575
Hi! I need some confirmation on my testing. From what I understand from the site, these numbers are ok except CYA is low. My pH doesn’t fluctuate hardly at all so I understand the high CH is probably ok..
My main question is, when I brush the pool, there is some dirt or algae(?) not sure which on the bottom. Overall, the water is completely clear and blue until I brush and I see some clouds as I go that quickly settle. Overall I have kept debris out of the water. My question is…does the presence of this dirt or algae while brushing mean I need to raise the FC to shock level? I don’t want to raise the CYA yet if so.
Other possibly relevant details…pool water is 57 degrees, not a ton of trees around and leaves are done falling, full sun.
Thank you so much!
CC 0
pH 7.8
CYA 40
TA 60
CH 575
Thank you so much!
