- Mar 24, 2014
- 2,455
- Plaster
- CircuPool SJ-55
Did you drain any water to lower CYA? How often are you testing and to what FC level are you dosing?
Just a thought... have you added any non-chlorine "shock"? That's stuff like Chlor-free and Oxone. MPS will give a false high CC reading.
If the pH is in range and the FC is above minimum for the CYA level, then technically I guess the pool is safe to swim in. People have been swimming in rivers and lakes and ponds with no test results for centuries and haven't been dying from it. But if that CC is CC and not interference, expect skin irritation and burning eyes.
Taking FC up to 31 is not so difficult. It's just a matter of emptying some jugs. If you get a good kill on whatever is growing -- and it can't be much if the water is clear -- then maintaining it shouldn't take any huge volume of bleach. It's just getting it up there initially that looks so daunting. And if it does have an unquenchable thirst for bleach, then it's just a matter of time before the pool turns to a swamp.
Also check for algae lurking behind lights and stairs and inside ladders. You still haven't filled out your signature so we have no clue what we're dealing with.
