Tomorrow I am installing a new 2HP variable speed pump to replace my old 1HP single speed. I'll explain the set up, but for now, juat note that both suction and return lines are 1.5" PVC.
I'll add pictures because there is a LOT of reducing and 1.5"-2" and vice versa...
SUCTION:
- 1.5" Cleaner line into 2" Jandy
- 1.5" Skimmer line into same 2"Jandy
- That 2" Jandy feeds into the pump at 1.5" reducer
PUMP TO FILTER:
- 2" leaving pump reduced to 1.5"
- 1.5" fed into 2" elbow that connects to 2" push pull
- 2" push pull reduces to 1.5" into 72 GPM DE filter
FILTER TO RETURN:
- 1.5" from filter to 2" push pull
- 2" push pull reduced to 1.5" return PVC
- 1.5" return PVC to 3/4" T connector for airator valve
- Other 1.5" side of the T feeds into a 2nd Jandy at 2" connection
- Jandy splits into two 1.5" returns (one for return jets, one for water feature)
Okay, so that's messy to read and even messier to look at. My question is about flow and pressure if I bypassed all the reducers and 1.5" to 2" craziness. KEEP IN MIND, both suction and return are 1.5".
Can I go from the two 1.5" suction to 2" into the Jandy & pump...2" into the 72 GPM filter...2" back into the return Jandy which feeds the two 1.5" return lines?
All safely and efficiently, of course
Will the new 2HP pump provide too much flow through 2" PVC for a 72 GPM filter and can this damage the returns going from 2" back to 1.5"?
I know I'll need to play with the RPM's but in theory, is this the 2" above ground PVC conversion a good or bad idea?
Thank you!
Thanks!
SUCTION:
PUMP TO FILTER:
FILTER TO RETURN:
Thank you!
Thanks!
