I'm really worried we're not on the same page here Rick,
The returns of a pools plumbing are behind the pump, from pump back to pool. A passive overflow device and a non return will not work in the return lines as passive overflow and return flow are heading in the same direction.
Again, are we talking about the return or suction side of the pump but more importantly any skimmer I've ever seen has the plumbing connection communing out of the bottom of the skimmer.
I think it's the other way around, I was assuming you would have a connection on the back end of the overflow or U and its this piece that provides the flow and suction to drive the syphon. A lot of your existing plumbing would make up the front und of a syphon including all the way to the bottom drain. Expect the unexpected, it's not just a rain event that can cause the possibility of a syphon, someone jumping in the pool would be enough to flood that section and suddenly your draining your pool to waste!
It sounds easy to swap out an elbow for a tee but in practice it can be quite tricky and once you start cutting into your existing plumbing it will never be the same again. You can't just swap one for another, you'll be swapping one for several and every extra fitting adds head pressure to the pump. If you cut into your existing plumbing it is flooded and all the water in the pool will drain out to that point.
My preference would be to provide a dedicated connection to the pool for a passive overflow but I don't see the point of going to all the trouble if you don't get enough rain to overflow your pool in an hour or two. Maybe it would be better to make a permanent connection from the valve you currently use to drain your pool to your 6" drain pipe. If I were you I would get the original pool builder back to 'quote' on your idea and get his ideas or advise.
Non returns do fail and it can damage the pump and your system when it does costing lots to fix.
Cheers,
Steve.
Sorry, I can't stop laughing at the whole Returns vs Suction thing... sorry if it was confusing, I tend to type quickly, and when my brain is thinking of "returning water to the pad" it ends up coming out in my reply. I hope we've all got a good idea that we're talking about the SUCTION side of the pump. Anyway, while I don't have a lot of experience dealing with siphons, I do have a good amount of experience with broader plumbing, more than enough to rebuild small portions of my pool's plumbing... which is pretty basic, and which I already did to build in a pad based auto-fill.
One the confusion, yeah, this is a gravity based "open to waste" system on the back side of the suction side plumbing in front of the pump. I'm not concerned about jumping in the pool effecting this at all. The level changes from jumping will be relative, and will have little/no impact down pipe within the reservoir (which I think is a reasonable idea).
Anyway, I think I've got everything I need here in terms of ideas, just need to think through the best way to incorporate it given that my "best" access (free pipe) is in front of the suction side valves (meaning I'll have to either drain the pool or cap the skimmer/drains directly).
Thanks for the insights.
Best,
Rick
