We are having a Radiant Metric 27-foot round installed. (18,600 gallons) Pentair pallet system with 1.0 hp pump and the 19 sand dollar filter.
I believe the pump and filter have 1.5-inch pipe connections. The skimmer will accept what sized pipe? The pump curve reads 12 psi at the filter equaling 40 GPM., turnover rate x 3 daily. The filter max is 40 GPM.
The pump/filter will be about 20 feet from the pool. I am thinking about going up to 2" schedule 40 from the skimmer to intake then adapting to pump and filter then back to 2".
Now for the confounding issue. I am constructing a DIY ground-mounted glazed solar heater. If I need more than one-panel system I will hook them in parallel. Each panel will have roughly 500 feet of 1/2" coiled poly irrigation hose hooked in series. (Rainbird). There will be about a 7-foot total height rise then fall back to the return side 2" manifold. (8-foot-long panel at a 40* tilt with some ground clearance. Preliminary research I did speculates at the calculated 12 psi I would have a flow rate of 3 GPM? I will have the first panel built and mounted in 3 days. I then can post with the actual BTU equivalents, flow rates, temp rises, and other data and pictures if requested.
Can I put a diverter valve in the proposed intake line prior to the 1 hp pump to feed the solar panel directly? 1.5 or 2-inch line here? Some websites suggest a 1.5" intake will handle 42 GPM and others 52 GPM??? If the skimmer accepts only a 1.5" pipe and I then upsize to a 2" pipe the rest of the way do I use the 42 GPM rate or the 2" 73 GPM service or some number inbetween? Cavitation= bad.
Finally, return the heated water to the discharge side of the filter and then mixed the water back into the pool inlet? Backflow valves needed? And how much head to add per bf valve?
Other options:: I have a 3/4 hp pool pump already. And a booster pump. (80 psi pressure rise! too much I think). Would it be better to use the 3/4 pump as a dedicated system for the solar heater using a bypass valve to control the solar flow rate and therefore the "heating time" in the solar complex? Then simply drop the heated and unheated return water over the side of the pool.?
Occam's razor leads to the second engineering solution. However, there is the extra electricity cost. AND how to get water to the intake side of the 3/4 pump. I am reluctant to drop a 120-volt sump pump into the pool. (AC electricity plus water plus electrolytes gives me pause). Aftermarket surgery on a pool with a lifetime warranty also makes me cautious.
Creative ideas, thoughts, and best wishes are all invited.
Thank you for taking the time to read my lengthy post!!!!
