- Feb 22, 2022
- 4
- Plaster
- Hayward Aqua Rite (T-15)
Hello!
We've had our pool for a little over a year (built new) and we've just started to have an issue over the weekend. When running our pump on anything above medium (75%) it begins to "pulse" and causes the pressure gauge to bounce all over the place. There is quite a bit of air in the pump basket, which I can normally get rid of by running the pump on high and opening the air relief on on the filter. But with it behaving as it is, I can't run it on high, and opening the pressure relief only lets water out.
Video Link of issue.
Some notes:
(edit to fix video link)
Some notes:
- It does this no matter what position the valves are in (all pool, all spa, sheer on/off, all valves partially open [mix of pool/spa]).
- The returns output pressure/volume is much lower than typical
- The filters were cleaned at the end of June, and again at the end of July.
- I haven't taken anything apart yet.
- Skimmer baskets are clean
- We get very little debris in the pool (no trees, etc.), usually a few small leaves per week.
