I'm considering upgrading my 9 year old Whisperflo 1.5 hp (011514) with an Intellifo VSF (011056). The reason is, as per Pentair it will be an exact match for plumbing since I have no more room to cut pvc.
My question is mostly about power. I'm currently on a 20 amp 240 breaker but it's wired to my Intermatic timer along with everything else. The Intelleflo requires power 24/7, so I would need to remove the pump wires from the timer and wire directly to the breaker. Is it ok to leave everything else on the intermatic? I don't want to get a new control center because I don't need it. And really I just let it all run 8-10 hours a day. So do I really need a variable speed pump to begin with? Once I set it I may never change it. Maybe I should just get another whisperflo?
Just looking for insight.
