Hi folks, been a while here but could use some more expert advice. Had my pool just over 3 years now, and like everyone in south Texas this week been keeping an eye on things with the below freezing temperatures. Everything seems to be working ok, however, I went out to spot check pumps this morning and noticed a small wet spot next to the pump that runs our lower set of spa jets. Further inspecting I saw water drops coming out of the motor assembly connection point. It only looks to be occurring when the pump is on at full pressure, as when it is off it dries up. So my question is A) is this a common point to find a leak at and B) is this something fairly easy to address? I'm plenty handy and comfortable acquiring parts and disassembling/reassembling, just never had to before on any of the pool equipment.
And with that, if it is something that can be fixed fairly easily, I do see and it makes sense that the Pentair instructions state to drain the pump out so you can do the disassembly. Well interestingly enough, this pump serves my lower spa jets as I mentioned. And the plumbing seems to be configured in such a way that if I remove the lid on this pump, the water just continues to spill out everywhere. So needless to say, cleaning the basket out has to be a speedy process. My assumption is that this line is completely under pressure at all times with the pressure/weight of the filled spa pushing into this line all the way back to the pump. So I was curious, did they miss adding some type of check valve possibly to prevent water for just continually spilling out of the top of the pump? Or is this how additional jets are normally plumbed in?
My thought is if I have to do any work to this pump, I might as well confirm any additional work that needs to be done to address the way it is plumbed...or if that is the correct way, then I'll most likely need to drain the spa first before servicing this pump. Any insight is greatly appreciated!
First attempt embedding Youtube link so if it doesn't work I've got a couple still shots of the leak attached as well.
Pump Leak YouTube
Pump Leak YouTube
