Hi all, long time lurker, first time poster!
Looking for some advice for things I can do now to make it easier on future-me for upgrades that I want to do when the budget is willing (shade enclosure, automation, load center, replacement heater for the spa). I've already removed the Polaris booster pump that died and replaced it with a Maytronics robot (thanks to y'all here and to Marina Pool & Spa!), on the to-do list is to plumb that line into another return.
But last month the filter pump started leaking something fierce with a noticeable daily drop in water level, not a good combo on an autofill water valve in Central California, so instead of trying to make a 10+ year old inefficient single speed limp along I decided to upgrade to a VS pump. Due to the stock issues everywhere, I managed to find an IntelliFlo3 VSF 3HP from Polytec Pools. I immediately ran into a spacing issue on the pad since the new pump is much longer than the old SuperFlo so currently I'm doing mental gymnastics to make it fit on the pad sideways.
I want to try to get it installed soon because the green swamp that is now my pool makes me more and more depressed every day, but is there anything else I should consider changing or adding now while I've got everything apart? See attached, all pipes are 2", foil is just to cover openings from landscaper's blowers, and included some pics from August right after we moved in with everything original on the pad.
Appreciate any info or insights y'all might have. Thanks!
