Of course I am out of town and the wife calls and says pump isnt working. But time clock is. I walk her through turning breakers on and off and try pump switch. She says it makes a knock noise but doesnt turn on. So I figure my pump motor is bad. The pump is a whisperflo WF23- 011771. It is a 3/4 Hp with a SF of 1.27 so 0.94sfhp. I want to get the century ecm16squ variable speed motor to replace and also the seal kit from inyopools. The problem is I need to know if I need to change the impeller and if so, to which one? I am not sure how impellers and ho are related. Please help so I can order the pump and have it delivered so I can install when I return. Thanks
