I have a Hayward Tristar 2-speed 1.5HP pump on my inground pool. I typically run it on low speed 12hrs a day. I had noticed that when I turn it on high speed this year that it was making a lot of noise like rocks bouncing around inside the pump. Low speed was not that noticeable. I got around to checking it out took the filter basket out etc and stuck my hand into try and turn the impeller. I was able to spin it but was pretty snug, did not feel any debris but can't say how thorough I was since the hole from the filter basket is small. Anyway when I fired the pump back up it seems as though I have lost like 5-10 PSI on the pump. Low speed barely registers above 0 PSI and high speed is now showing around 15-20 PSI. I assume my gauge is fine since it actually is moving and it was probably replaced in last 2 years. Both Hi/Low speeds still moving water but feeling as though I need to run it on high all the time now to get the right turn over. Anyway looking for thoughts if the motor might be going bad or if I should consider replacing impeller all together or something else. To note I have a Hayward Sand filter as well and sand has not been changed in 4 years probably but by the previous sounds coming out of the pump and the sudden change in pressure on the gauge after inspecting the pump certainly seems pump related.
