- May 3, 2007
- 16,964
- Plaster
- Hayward Aqua Rite (T-15)
Re: Pump power w/ different impellers, 2-speed vs VS w/ sola
Assuming there is a vacuum release valve installed, you should here air getting purged out of the panels when the panels are priming. If you do not see large bubbles come out of your returns, then the flow is not high enough to the panels.
Also, the SWG should have an alarm of some sort to tell you if the flow rate is too low.
I only said that because that is what I thought the plumbing did. Looking at the pictures, it is hard to tell. But the return pluming still goes straight out the return which is still ok. The only issue is the SWG. If they had plumbed it differently, all the water would go through the SWG with solar on or off.Now you mentioned previously that the current piping should return the solar flow past the manual valve on the fork after the pump (to the right in the pic) opposite the flow to solar? Maybe where the water flow after solar goes now is to the gas heater, so we wouldn't want to reduce that flow? Or should I ask them to redirect some of the piping?
