mas985 said:The check valve for solar should be right after the filter and before the solar valve. There should be a second check valve on the return solar before it gets plumbed back into the main return line.
I understand I need 2 check valves: I need to add one after the filter and plan to replace the current one after the solar to the more efficient flapper style.
mas985 said:You could actually plumb the solar return after the heater if it is easier.
Currently the heater exit pipe goes horizontal PAST the return pipe. I am suggesting to just drop it straight down to the return pipe with just 2 90s.
Still not getting it . Currently all the water goes through the heater and then though the solar if open. Most diagrams I see say to go through the solar if open and then through the heater, which is what I was trying to do. The easiest would be to just leave the heater before the solar and add the bypass there, although then I could not run both (might be rare to do this except for special weekend occasions in the shoulder seasons.
It almost sound like you are suggesting I enter the heater before the solar, but return from the heater AFTER the solar. Seems like even with the bypass open, the least resistance might be through the heater, and not going to the solar. Or did you mean to bring both the inlet and outlet of the heater to the return line after the solar?
mas985 said:For the new suction, you might be able to find a screw in cover. Just look at some online places that have fittings and see what will work. Either dual two ways or a 3-way would be fine.
I will see what I can find. Had not run across a screw in cover yet.
