Hello,
My pool pump is failing to prime itself (no flow warning). If I put it on pool / spa boost instead of filter, I can get it to eventually prime with about 6 buckets of water. I have always had issues with this pool priming (this seems to happen once a year). The pool technician that came out a while back said they should not have designed the pool to go uphill. I cleaned out the DE filter and re-added DE hoping that would fix it, but no luck. There is one leak, which I am hoping to seal that may be causing air loss here. We recently had someone install a new pump and afterwards we have some water leaking out of the top of the filter junction (I don't know the name). I have checked the O ring in this junction and it looked ok to me, and I also added a bunch of Jacks lube to try to stop the leak. It still leaks once the filter gets going. It has a hand tighten type locking mechanism that won't tighten very far (if you try to over tighten it just loosens if that makes any sense). I have attached 3 pictures of what this looks like. How can I seal this to get rid of this leak?
Thanks!
Thanks!
