The smoke test will find large suction side leaks, and it's good that you performed the test, but again,,, Does your pump pot accumulate an air bubble while the pump is running, and if so how quickly does the bubble form?
Using a hose to pour water on the connections is a better way to find suction side leaks.
Have your tried Hayward, Jack's lube on the strainer lid "O" ring?
If you see air bubbles coming out of the return lines in your pool, you likely have a leak. Some signs that a suction side plumbing leak has occurred include: Read more
www.troublefreepool.com
If you do not accumulate an air bubble while the pump is running, then are you losing prime when the pump is off. Somehow your pump/plumbing is losing water while the system is off,,,, how long does it take to drain out enough water to not allow a prime?
If your system is draining back after the pump is off, one culprit could be your mulit-port valve. If the valve is the problem, it could be leaking into your backwash line, which is a leak you might not see easily. Then when the pump is off, this would allow air to enter the system and the water would drain from the pump back to the pool. Take a look at the backwash outlet while the pump is running, to see if you have any leakage.
