My pool was up and running and I decided to replace the shaft seal and impeller since I just got a new motor in that was way long overdue. I have a Superpump and a multi valve. I put the multi-valve on close and took the motor assembly from the pump. I then replaced all the parts as well as the housing gasket with Hayward parts. I put in the new housing gasket and put everything back together. I set the multi-valve to filter and put on the power. When I did, water started to leak from the pump assembly area and even out of the motor air openings in the back. I'm not sure what I did wrong. Could it be from putting the valve to close and then filter creating pressure? Maybe the housing gasket was off? I'm pretty sure I replaced the shaft seal correctly from watching some youtube videos. Thank you.
