- Aug 22, 2010
- 20
Hey gang-
i'm at my wits end with this- hoping someone can help before i have to bite the bullet on a new motor.
Here's the skinny: noticed my 7 year old pentair whisper flo WFDS-6 2 speed pump (# 011522) wouldn't turn on when low speed was engaged- pump just hummed. Once the high speed was engaged, the pump would start up & run normally. Once i turn the off high speed, low speed will run normally so long as high speed was on first.
I checked the impeller shaft at rear of motor and I was unable to spin by hand. Figured it was a bearing or seal. Took pump & motor apart, greased rear bearing (couldn't remove cover to access bearing closest to front of pump) and replaced the pump seal. Spun freely- thought i was home fee. Same problem: low speed hum.
Replaced the capacitor just in case as well, but no luck. Same problem- low speed hum. Not sure what to do short of buying new motor at this point. Any ideas?
