I have the same exact type of pipe going to the crushed concrete layer under the pool. The builder used it to extract ground water between sealing the pool shell for plastering, and then filling with water. Once filled with water, mine is no longer needed (unless the pool needs to be replastered I guess, so it can be resealed and refilled safely without ground water entering the hydrostatic relief valves and staining the plaster). I capped the pipe, marked where it is on a little map I have of my property, and buried it.
My initial thoughts would be ask the builder if yours is the same and you can just ignore it, or, if it serves some useful purpose, ask what is the purpose and what pump do they suggest for it. If you have a vinyl liner and high ground water table, maybe that was why they put it there?
