- Jan 4, 2016
- 5,293
- Plaster
At least one SWCG manufacturer is including an instruction on their saltwater chlorinator cells: "ACID CLEAN EVERY 3 MONTHS"
Doing so will significantly reduce the life of your saltwater chlorinator cell. For pool water that is kept well-balanced using TFPC, acid cleaning is seldom necessary.
Look inside to see if there's any scale. It will appear as a light beige to nearly white accumulation between the plates. You may be able to spray it out or gently pick it out with a soft wood or plastic tool. Do not scrape with a metal tool of any kind. Some SWCG cells have clear bodies for the purpose of seeing scale early in its development.
If you're accumulating scale in your cell, revisit your water chemistry approach and consider keeping the calcite saturation index (CSI) slightly below zero to prevent scale. Where you can see minor amounts of scale in your saltwater chlorinator cell, this will be dissolved very, very slowly in slightly negative CSI water (e.g. across a few months swimming season).
If money is no object, have at it, and do it safely.
