I'm making progress. Today I figured out the leaf eater and blind scooped a lot of pool crud. The loud noises I heard last night were two frogs that moved in. I evicted one this morning, the other is going to pack up and go or will discover a new interpretation of an old adage. I also replaced the pressure valve on the sand filter today. After backwashing it reads about 12 PSI running, and 0 stopped. Feels like a nice, solid gauge. Thanks, Dave S.!
This is in stark comparison to my old flimsy gauge, which reads around 60 PSI pretty much all the time.
I think I've figured out how the Jandy valve works now: the skimmer flows in from the right, the main drain from below, and the outlet to the pump above. The stop indicates where the plate will slide, prohibiting flow to/from that direction. But I'm curious as to why it is "stopped" the way it is. It seems like Jandy valves were really intended for two outlets and one inlet, and clearly pool owners are using them the other way. On my valve, the stop will slide to block the main drain and do skimmer only (DOWN), open both inlets (LEFT), or dead head the pump (UP). It will not block the skimmer and do main drain only, which garners from me an expletive worth deleting.
Can I open the valve and change it so it stops to prevent the UP setting only?
I also got the pump to run for a few hours, although it sputtered for a while. I took some test readings, entered them into Simple Pool Professional on my phone, and while I was looking for the thermometer gun managed to press the back button and lose all my results. To the best of my recollection, I got
pH:~8.5, TA:160, CYA:55, CH: 260, and Salt:2800. As I recently suspected, my CYA reading was much lower than my original reading, this time I did it in full sunlight with the sun to my back and the tube at waist level. I'm going to test again tomorrow to be sure (and I'm happy I bought extra CYA reagent!). I'm also pleased that this means I won't have to drain the pool any.
I'm stocking up on pool chemicals, getting ready to SLAM. This shelf looks a lot different than the shelf from the previous owner.
Should I bother trying to do a comprehensive estimate of the pool volume, or is the pool inspector's "analysis" of 15k gallons good enough?
If the Polaris/booster pump is broke, I'd consider getting a robotic. I really like using mine to clean and vacuum while I'm cleaning my DE filter on start up of a really dirty pool.. It can really help speed up the time to turning a green pool to blue.
I would love that, but we're pretty strapped right now after the move to the new house. It's going to have to be "The Human Brushmaster" for the time being!
My lab (Casey RIP) never used the pool when no one was out there. She always waited for me to give the green light which was usually a ball thrown in! Once she saw me in my bikini though... that was that, she started howling in excitement because she knew was going swimming!
That's adorable!
