Do you mean, the skimmer side, up by the pool, or on the opposite side of the gate valve - the photo I took, but the other side?
adoptolderkids said:Do you mean, the skimmer side, up by the pool, or on the opposite side of the gate valve - the photo I took, but the other side?
RobbieH said:That's where mine was leaking, the basket drain port!
Bama Rambler said:Glad you got that fixed and now it's on to the clearing. You can start vacuuming again.
JesseWV said:RobbieH said:That's where mine was leaking, the basket drain port!
Heck I didn't even notice that in any of the pictures. So all this time you could have easily ended her agony with a simple "Is there a drain port on the pump basket?" Hahaha!
Perhaps the journey itself is more rewarding than arriving at the destination.
Ha Ha - I know, thanks for your "help" Robbie! From now on, that should be your go-to answer for everything, so it doesn't accidentally get overlooked again!So all this time you could have easily ended her agony with a simple "Is there a drain port on the pump basket?" Hahaha!
Somehow I think more stirring was happening than vacuuming without an actual "vacuum" in the pump housing!
It is o.k. to backwash when you are using the sock method to add CYA. You would only not backwash if you had just dumped dry CYA into the pool or skimmer basket where it would get caught in the filter until it had dissolved or been backwashed out.
Running the vacuum should be much more effective now too, should you choose to do so.
Just keep shocking and getting as much stuff out as you can.
