- Aug 7, 2023
- 56
- Vinyl
- CircuPool RJ-60 Plus
I have an above ground vinyl lined pool. When we first purchased the pool a SWG was considered. I had an Intex pool that I used one with. However, I was told that SWG would errode and decay the pool frame as well as pool equipment. My pool was installed with a Pool Frog system which I am ready to ditch. I'm not going to be moving away from using Chlorine pucks, as my CYA levels are high from use of. I don't necessarily want to be manually adding liquid chlorine daily. I'm just curious about this group's take on SWG's and above ground pools.
