Hey all,
First post here. Glad to find the group and I appreciate advice you all have. I'm writing from Lake Orion, MI. I've got a background in chemistry and lab work and I'm still finding myself having issues applying a lot of the vague information available online when it comes to the proper shock technique for one of these Master spas with the "eco pur" mineral stick (zinc and copper I believe) in addition to ozone running.
Long story short, MasterSpa for reasons that are unclear to me recommend that their spas be sanitized only with dichlor (we happen to use SpaBoss brand) and that they are shocked only with non-chlorinated MPS (we happen to use SpaBoss energize as recommended by our dealer). I'm having issues where within a week of modest dichlor usage (tablespoon every 1-2 days depending on FC readings) after a fresh fill with our city water (usually about 3 ppm FC out of the tap) we are starting to develop what looks like a chlorine lock with really high combined chlorine using our Taylor test kit. I was previously using an Oto test kit and after 4-5 weeks we tended to require more and more dichlor to keep the FC up and the water clear so I'm assuming up until I switched to the DPD kit our tub was suffering from some combination of excessive CYA and/or chlorine lock that we didn't know about.
With our current situation of one week old water and really high CC despite FC of 3 ppm I have tried twice to shock the tub as directed with our MPS non-chlorinated oxidizing shock and our readings the next day with respect to TC, CC, and FC are unchanged.
Am I barking up the wrong tree here by using this dichlor sanitizer and MPS shock routine as directed by our dealer? Is there a reason that adding the recommended amount of MPS (and then some) wouldn't be helping to convert this CC back to FC in a relatively fresh fill? Is the MPS somehow causing false readings 24h later on my Taylor test kit (I was under the impression it would have dissipated by then)?
It's a 2 year old 395 gallon tub with a relatively low bather load (small family) and I generally end up changing the water every 2 months and clean the filters frequently. I'm pretty meticulous about keeping the TA and pH within recommend ranges also.
Would love to hear anyone's thoughts on this.
Thanks all!
Dan
Master Spa LSX 850
395 Gallons with "EcoPur" mineral stick and ozonator.
Thanks all!
Dan
Master Spa LSX 850
