Problem with vacuuming to waste
amin36
In The Industry
Nov 24, 2017
189
shahsavar
Guys
Today I went to a client's pool and he asked for me to teach him how to manually vacuum the pool.
He used flocculent and it all sat at the bottom of the pool and I wanted to vacuum the water to waste.
He didn't have a vacuum plate so I directly attached the vacuum head to the skimmer with a hose connector.
So I closed the bottom drains and while the sand filter was running on filter mode I primed the hose using one of the returns.
I had a very good suction so I stopped the pump and put the filter on waste. When I started the pump I had a very weak suction.
I couldn't figure out what is happening so while the filter was on waste mode I tried different ways of priming the hose and still no results
I even checked to see for usual problems while manually vacuuming the pool but there was nothing wrong.
After all the suction was great when priming the hose on filter mode.
Any ideas what is going on here?
