This is my problem: the colors in the test block are lemon yellow and pink each in various degrees, but when I add the testing drops the results are in a golden yellow and in red. I can never get a color match, and I am not able to translate the golden/red results to the lemon/pink colors. So I revert to do the chlorine drop test and using the PH meter. The latter is rather quick, but the chlorine test is not.
Is there an alternative daily check method I can use? I realize that this may be a small problem, but considering myself still a newbie and trying to get a handle on pool maintenance it is really bugging me.
Thank you.
Thank you.
