Hello. After finally finishing a diy oval pool install. Some of the sand base looks too have been pushed away away from one of the pressure plates and now the end of it is visible through the liner. Guessing just not packed enough under the plates. Is the only solution to completely drain the pool and remove liner to relevel the base? Or should i just not worry about it?
