Pressure keeps going high.
May 15, 2013
77
Ct
Just bought a whole new fin set up. When I start the filter, it starts at 10, stays for a while then goes to 20-25. I wash the filter every few days because its still cloudy and so much pollen and tree debris is coming down. I find I am backwashing multiple times a day. Even after I wash the filter the pressure goes up. At 10 it is like a hurricane, then slows down. Is this normal
It sounds like the filter is working properly. You say the pool is cloudy also? There is probably more going on in the pool and it's clogging the filter as would be expected. Do you have a Test Kit you can give us some readings with?
