Typically, a 1 hp total hp motor uses about 1,000 watts.
the hp rating is confusing because it is the hp delivered to the water and not the total hp used.
There is also a "Service Factor" on older models that is now mostly gone.
In any case, check the amperage on the label and multiply the volts by the amps to get the watts.
For example, this motor is listed as a 1.25 total hp motor and the wattage comes out to about 1,610 at full maximum load.
230 x 7.0 = 1,610 watts.
For most operations, the actual amperage will be about 75% to 80% of the label listed full load amperage.
230 x 5.43 amps = 1,250 watts.
It also depends on the actual impeller.
If you use a smaller impeller, the power draw will be lower.
