- Sep 24, 2022
- 17
- Plaster
- Pentair Intellichlor IC-60
Hi everyone. Couple questions regarding my coping and decking for my gunite pool currently under construction.
I'm in the desert landscape of Henderson Nevada. We're doing poured concrete coping and decking. My PB says I don't need an expansion joint between them OR between the coping and bond beam, because the soil isn't expansive. I don't agree, nor do I want a solid one-piece cantilever pour so I'm demanding the expansion joint between the coping and decking, having them be completely separate.
Couple questions
PB says they can pour the coping and decking at the same time, just using foam between them. I assume this can be done, but is this normal practice? Or is the deck usually poured on a separate day?
Do you just try and push the foam down and fill in with backer rod and caulk to finish the expansion joint?
Lastly, I have a (2) 4ft sections of 18" raised bond beam with a 5ft tall modern grotto between them. The spa is also raised 18". All with concrete deck around them. I've tried to find info on this but haven't had a lot of luck specifically regarding decking butting up against a raised bond beam. Do I need an expansion joint between the raised beam and the concrete decking or are the raised portions strong enough to not need one?
Appreciate your time and feedback. I'll try and post pics tomorrow, I know that helps.
Couple questions
